505'sFastestViper.
no such thing as too much boost!!!!!!!!!!!moparracing said:he's got too much boost, over-nighting some different pulley's - should know more in da mornin'.
505'sFastestViper. said:no such thing as too much boost!!!!!!!!!!!
Haha, funny i was thinking the same thing as I was reading your post.505'sFastestViper. said:no such thing as too much boost!!!!!!!!!!!
SHU-DOG said:What would just letting the blow-off valve do its job?
Or does it create tooo much heat and other problems?
I have a blow off valve for eliminating pressure when the throttle is closed.Ram From Hell said:Adding a blow-off valve with a boost controller is possible. I believe this is the setup that FSTJACK has on his red truck. .
FSTJACK said:I have a blow off valve for eliminating pressure when the throttle is closed.
I also have a waste gate in the system that is CO2 powered and uses an electronic boost controller.
With this setup I can regulate boost to any level I want, with any boost output created by the blower.
I have complete control over the boost pressure just like a turbo would have with a boost controller.
The boost controller I am using is an AMS1000.
Silverback said:A waste gate is used with a turbo and bleeds off the exhaust gases to the turbo to control boost. I just allows some of the exhaust to bypass the turbo.
