So, I finally got around to redoing a set of brake calipers. I have never powder coated before, so I thought I'd give it a try.
I'm using summit powder red and clear. Both cure time/temps the same. 392F for 8 minutes when part reaches temperature.
I have smoothed and totally cleaned/outgassed calipers.
I sprayed the red and cured for 5 minutes.
I applied the white high temp viper decals.
I sprayed the clear and cured for the full 8 minutes.
The problem occurred during the last minute of cure time. The white decals turned slightly pink.
Is this an issue with the decal? Or should I have cured the red a little longer? Or is this the nature of the beast?
Thanks for the help!
