JonByrne13
I recently picked up an 05 Ram SRT-10 with 33k... I have had nothing but issues since getting it last August... I have literally driven my "driver" 100 miles since getting it... that is my rant, now it is over.
My problem: While doing some repairs I noticed that the top fitting on the p/s pump was not fully seated in the pump, I removed the line and found it to be cross threaded. I picked up a replacement pump and when going to install it I noticed a difference where the reservoir connects to the pump. (Please see attachment)
Has anyone else installed a pump with this difference? My fear is that it will not properly seal and a stream of pissed p/s fluid will be the result of my first fire...
Also, I am trying to rationalize the configuration of the adapter piece that goes between the pump and the reservoir, I do not have much confidence in the person that installed the last reman pump and would like confirmation on the correct way to install it. (Please see attachment and reference option a or b in your response, unless neither is it, then just say I am fucked up)
I appreciate any help and moral support through these hard times.
DV13
DV13
