SRT-10 RAM VIPER
Guys i have some ?s for the pro charger set up. What modifications do i have to do to my engine
How much can the stock engine hold. I dont want to blow my engine. Also where can i get the basic pro charger
If someone sends me a pro charger I will put it on my truck and I will tell you how many HP it puts out.
I recently just purchased a F1 kit from JMB to run on a stock motor set up. He says it will be fine for this running around 5-7psi should make between 600-640rwhp with a few other mods I am doing.
upgraded fuel pump $175How much was your kit out the door? I know it lists for $6999, but was there anything else you purchased, such as upgraded fueling or anything else?
Awesome man, thank you. And I respect you posting what you paid, a lot of guys won't. I would have PM'd you, but you don't have enough posts. And you're right man, Justin is top notch.
injectors $600
Map sensor $18
Plugs $28
Coolant tank $70
I also bought a ATI balancer wasnt necessay but highly recommended $460
Rougly around $7891 with out ATI and $8351
the customer service and smile it will put on your face PRICELESS!!!!![]()
Did you cut keyways in the crank to utilize the ATI or did you buy the one without keyways?
