Probably a Rare Mod
TeamSRT10
Eastern Pennsylvania
Has anyone thought about changing the column shift of a 2005 or 2006 Quad to a automatic floor shift? I think it could work if the ppl but who knows.
someone alredy did it I am sure they will chim in.:p
thanks blackviper..........Looks like the floor shift from the F-150's. Was that the only one that could work? Did u do it or a shop and how much was it to be converted if u dont mind saying.
Dodge does it now on the 09's.....it an upgrade when you buy a new one.
Parts needed are the F150 shifter, a new shifter cable, spacers to raise the shifter to the correct height, the lower steering column cover off an RC, and recover the center console piece after the hole for shifter has been cut out. One thing, it's a little tricky getting the linkage at the transmission to work correctly to match the shifter spacing between gears. You will half to space out the plate where the shifter cable hooks up to the transmission about half an inch. There is not enough adjustment at the shifter cable ends.
