Hi All!
I'm a newbie to the VTCOA and I wanted to know if anyone has had problems with their 48RE transmission shifting during cold temperatures. Mine is taking a long time to complete shifts and the shifts are quite hard when they do finally engage. One time, during very cold temps, I pulled up to a stop sign and 10 seconds later (after I had come to a complete stop) the tranny completed its downshift. It felt like I had been bumped from behind by another car! The problem disappears after the tranny warms up. I begin to notice the problem when temps drop below 40-45 degrees outside.
I have read about ATF+4 fluid being the fluid of choice since 2005 and noted it has better cold temperature flowability. But, I'm not sure what type came stock in mine since Chrysler states they discontinued ATF+3 in the same year.
I've also read about torque converter drain back due to unproperly torqued valve body bolts.
And of course there's always the possibility of having a bad sensor.
Just thought I'd through this out there and see if any of you have ever experienced the same problems.
BTW - I live in Denver (not the greatest place to have an SRT-10 in the winter!)
Thanks,
Jim
Thanks,
Jim
