problems
SRT-10 RAM VIPER
DENVER, CO
Ok guys so i added an aftermarket sound system. I'm gonna be running stock radio for now. Everything is connected in but the problem is the subwoofers wont bump i checked every wire and everything looks good. What could it be?
howdy little buddy
did ya get ya sub signal at/from the stock sub amp???
Based on the vast amount of information you provided, I'd say the problem is that something isn't working.
So I've been thinking, Freddy, did you check all the wires? Because, it could be a wire problem. If I think of anything else, I'll let you know!
I was told by our local stereo Guru that if your system did work. the worse it sounds the easier it is to fix. Good luck!
I think that the amp reversed polarity
Disconnect your battery to rest polarity happened to mine the other day
Dom
Undefeated on the Internet
