Hey Y'all,
I just had my Ezlift installed in the tailgate of my truck..... I must admit that I didn't put it in myself....But what the hell....
The ezlift has got to be the simplest non-gadget ever created for the purpose of taking the weight off your tailgate.... It is essentially a torsion bar... a 3 sided rectangle consisting of one long leg and two short legs.....
You drill a hole in the sidewall near the hinge of your tailgate and another hole near the center of the lower edge of the tailgate itself.....the two short legs of the rectangle go (one each) into these two holes....
Once installed, these two ends remove the weight in both the up and down movement of the tailgate due to the fact that they are always trying to return to their upright position. Thus assisting in both raising and lowering the tailgate....
It's so simple, I don't understand why the damn this isn't standard equipment...It's probably a total of 2 dollars worth of spring steel...
Once installed, your tailgate raises and lowers literally with two fingers....
I think it cost me about 30 bux.........
It's made by Hopkins manufacturing.... Here's the link:
http://www.hopkinsmfg.com/contactusintro.html
By the way, it's hard to find it sold anywhere else... I tried... Just buy it from the manufacturer...
SD
SD
