mopower1958 said:Jack is that a dummy motor in it or is that the assembled beast?
I can answer that one for Jack.
It's a dummy motor.
BlackViperRam04 said:I'm going to be in Oceanside/San Marcos next week. Is your truck at RPM right now? If it is I think I am going to drop in there to check it out if you don't mind.
1500hp...........easy.:rock:mosrt10 said:Jack I can't wait to see what machine lays down on the dyno.
BOOMER said:1500hp...........easy.:rock:
Sharpimage said:Ya know.. someone told me the block is only good for 1600HP... is there
any truth in that? :dontknow:Sharpi
BOOMER said:beautiful, very nice. are those Burns collectors? looks friggin awesome, very well done
dragon said:holy horsepower batman. looks like your upper rad hose i a little close to the intake tube.
very very beautiful work. old world craftsmanship at its best. thanks for sharing, its inspiring to see people like this are still out there.FSTJACK said:Gary, the stainles collectors and tubing came from SPD, Specialty Design Products in Rancho Cordoba. They make really high quality products on a par with Burns.
Richard had the collectors/flanges made to order. Richard designed and made the header tubes so they enter into the collectors in a rotational pattern matching the engine firing order.
Richard is a very crafty guy...................:rock:
This project might not have been possible without him. He does things the right/correct way. Richard is a good friend as well as a vendor here. I can't say enough good things about him and the men he has on staff.
FSTJACK said:There is truth in that, depending on what has been done to the block and the paripherals. Kevin from Exotic Engine Development has done a tremendous amount of work to the block with sleves, main caps, main cap girdle, ect.
If you look at the attached picture it shows one side of a front motor mounting plate, that attaches to the frame. We have also mid plated between the transmission and the block. This mounts the block to the frame at all 4 corners and does not use the stock motor mounts. This was all custom fabricated and machined for this truck and motor.
This will hopefully keep the block from twisting so much.
There is also a much bigger motor on the drawing board..........:idea:.........:afraid:
I think what we have now will allow us to make lots of HP, 1500++ and keep it alive. But it's a hotrod so knowbody knows untill it's burning 118..
http://www.vtcoa.com/forums/attachment.php?attachmentid=15484&d=1182582611
bigike said:All this Motor talk makes me sick....... the motors in these trucks are used to clean the windshield, roll the windows up and down and lock the doors...... The prime mover is called a Engine!!!!!!!!!!!!
man that is some beautiful work, any chance youll post a price list?
