TREKER
I have had an ongoing issue with my clutch. I am looking to replace it soon but I do not think it is the clutch itself.
I took it out today because I am going to take it to a local transmission guy across from my office. The pedal goes all the way to floor without engaging or disengaging the clutch. Only after I pump the pedal do I get pressure enough to shift. When I pump pedal 10 times, I get enough pressure to get from 1st to 2nd, and maybe third before I cannot even get it out of gear without pumping it up again.
It got so bad that I had to pull over. I opened the master for the clutch cap and added a little fluid. (It was actually full still but looked kinda cloudy) Got back in, started it, and had perfect clutch again, but only for a short time.
Questions..
1. How can I nail down exactly what the issue is?
2. Is this the problem that occurs due to the stock plastic hydraulics?
Thanks
Questions..
Thanks
