LORD CHAVEZ
Has anyone had trouble when pumping gas. Mine has been spittin it back out lately. Does it have air in it or what.
There's a check ball that can get lodged in your main hoses from filler. Try getting under and tapping around on line
We don't pump our gas here in nj
Pumping 87 octane into our trucks can certainly ruin your day (also the motor)..shit I remember when leaded 102 octane at 35 cents a gallon was the way to go back in the early 70's.
In my civic i'm running so much timing that regular will foul my plugs in a mile or less.
No bro they're giving you shit. I believe it's the check ball that prevents gas from coming out during a rollover. Have you tried tapping the fuel neck, hose and all you can get to? Remove lines if you have to and see if your can run a thinner hose into vent and filler and see if you can free rollover valve. If your truck is covered with ice as most are seeing it puddles on top of tank and freezes and could get condensation in check ball, freezing it in place.
Often overfilling can cause this as well.![]()
What?....:dontknow:
Wouldnt the fuel melt the frozen condensation?
It's usually in the vent line that doesn't see fuel unless overfilled then fuel runs into vent. Seems many with ice conditions, not so much snow, have experienced this. I worked for Dodge years back when these were new and all rams and vans had this issue when we had an ice/sleet storm where its raining like heck then starts freezing leaving a think ice layer on tank, hoses, but especially that vent/overflow tube as it doesn't/cant have a cap.
