Q??? on valve springs, Help!
stealth78
MA
What are you guys using for springs compatible with a 550-600 lift cam? Crowers springs are 1.050 O.D. and Comp is 1.509 (Dual). Comp also says head modifications are necessary...??? I know everyone is big on custom grinds but the guy doing my heads has run different cam profiles through his program and he said the 587 cam that Crower offers is right on the button for what I'm looking for (PLEASE CHIME IN IF YOU KNOW SOMETHING WE DON'T!). Have any of you guys had to make any head modifications? Also, I am staying with stock rockers so no need for valve cover spacers. THANKS IN ADVANCE!!!
You can run the comp or crower beehive springs to avoid machining spring seats. Basically what we run on LS engines sir. What are you specs on that 587 cam?
Part Number
36427
Engine Make
Chrysler/Dodge/Mopar
Year
2003-up
Part Class
Camshaft
Camshaft Name
Stage 3
Camshaft Series
Original
Engine Type
V10
Engine Size
Viper
Product Type
Hydraulic Roller
Valve Lash
.000" intake and .000" exhaust
Lobe center
114
Advertised Duration: Intake / Exhaust
300 / 300
Duration @ .050" Lift: Intake / Exhaust
238 / 238
Lobe Lift: Intake / Exhaust
.345 / .345
Rocker Ratio: Intake / Exhaust
1.7 / 1.7
Gross Valve Lift: Intake / Exhaust
.587 / .587
Low RPM
1250
Peak HP
6500
Redline
7000
Performance Description
Race/Strip, rough idle, ECU mods recommended.
Recommended Kit #1
84550
Part Number
36427
Engine Make
Year
2003-up
Part Class
Camshaft
Camshaft Name
Stage 3
Camshaft Series
Original
Engine Type
V10
Engine Size
Viper
Product Type
Hydraulic Roller
Valve Lash
Lobe center
114
300 / 300
238 / 238
.345 / .345
1.7 / 1.7
.587 / .587
Low RPM
1250
Peak HP
6500
Redline
7000
Recommended Kit #1
84550
That ought a be a pretty good cam for your desires.
That lift is fine with a comp 918 spring. PAC, Crower, Brian Tooley, all these springs are good.
Do you recommend titanium retainers or would the steel ones be fine?
Your not done with this build yet???? LOL
Do it once, do it right. IMO, go with the best when you have it apart.
I know I know... Was just wondering any of yall's personal opinions/experience. My head guy said he didn't see a need for the titanium ones being that it's not going to be a high rpm application, he said if this thing was going to spin 8000rpm's it would be a no brainer... in his opinion. Personally, I have no idea :D
I would stay with the steel ones. titanium are expensive ! you want durability for street driving more than light weight................just my opinion.
