Question about high flow cats
framk25
Does any one know if high flow cat pass Ca. smog check?
Note the truck does not have any cats, trying to get it registered.
as for tail pipe emissions should be no problem, however, if you are getting a visual inspection (normal in Calif) it will not pass unless there are 4 cats and if not OEM factory they will require documentation as to why the factory cats were replaced. Been there done that....:mad: I know several who found shops who only cared about tailpipe emissions and passed them. Unfortunately, the shop I went to with my other vehicle documented i.e. red flagged me in the system. I ended up having to go to CARB directly before I was passed.
just get a set of factory mids and then swap it in and then out once passed, I am sure a member closer to you will have a set cheap
