Is removing my mid cats going to effect my emmisions when its time to get tested??
moparman95 said:Damn.. I figured as much. Just making sure. Any suggestions on a good exhaust system? Should I bother going with a cat back? I bought the truck used, and it's true dual all the way back from the manifold. Do they come stock like that? Would it be better if I installed an H pipe, or an X pipe?? These trucks are new to me, I spent the last 10 years building/playing with 5.2/5.9's, and decided to upgrade to the big boys.
exactly check with you local inspection station first , ask the requirments,RB04 said:depends on how your state does the test, here in CT they just plug into the obd, if no codes you pass, I have the b+b and only 2 high flow cats and passed with flying colors
