KRAZYSRT10
- Joined
- Sep 2, 2006
- Messages
- 9,647
- Reaction score
- 0
Stinker said:Kinda tired right now but will post instructions tommorrow, but basically if you lay under the truck head front feet rear under tranny, look at the drivers side find the shift cable and fluid lines, jsut above the fluid lines you will see a stud kickin out of the tranny with a lock bolt, the other is inside the tranny much easier to get to , just service the tranny with a new filter and you will easily see the band adjuster.
but what you do is loosen the lock nut, tight down the adjuster bolt to a specified torque , then back it off a number of rounds, then tighten lock nut.
done ,, easy
I will take time to post a thread tommorrow with detailed instructions, if I dont ....someone kick me in the nutts and wake me up
And commencing the kicking NOW....:boxing: :banghead: :slug: :thefinger:
