Questions about cal-tracs
bclark05
Hudson Falls,NY
I just installed Stinkers drop kit and Cal-tracs. I was just wondering how and when to adjust the Cal-tracs?:dontknow:How much do I adjust at a time when I do make adjustments?:dontknow: I am running mostly on the street, with street tires.:burnout: When do I know that the Cal-tracs are working to there max? Thanks for all the input
run both sides down till they touch then run them one more turn and tighten them down. or if you have help sit in the truck and do the same procedure. some have tightened them on down at the track if it spins more than it should.
i was thinking about Cal tracs with my flip kit and an anti sway bar would all that work together?
plus Cal tracs look cool :D
You had to remove the smallest leaf as well to install the caltracs?
Got pic's?
This is the front 32"
[/IMG]
This is the back 34"
[/IMG]
[/IMG]
Cal-Tracs bottom leaf flipped and left in, to get the rake.
[/IMG]
The look is great.
[/IMG]
[/IMG]
[/IMG]
Thank you Stinker and Amtrucker22:congrats:
amtrucker22 said:
Very nice stance bro!!! How much of the bump stops did you cut down? Any rubbing?
I didn't cut them at all, left them alone. no rubbing yet , but I only have about ten miles on it. Still have to get the rear welded and the alignment is saturday.
