What's the best way to install this thing before I just tear into it:dontknow: Also where's the best spot to put it?
FastSRT19 said:Just did mine...very easy. I did strip back the covering a bit..probably 12 inches or so. And i cut a tiny hole in the round rubber grommet down in front iof the clutch lever on the firewall to get the RPM wire to the PCM. I ran the wire across the engine compartment inside the black plastic shroud that goes all the way across the truck. I opened up the tabs with an icepick and tucked the wire inside, then closed her back up. I mounted the light just to the right of the hazard light button on top of the steering column.
If you have any more questions, PM me. I'll be glad to help:burnout:
