RB4 Radio wiring color help? Need the ignition wire color and ground?
kickinassrt-10
Miami, Fl
I am installing a FM modulator in my truck and I bought the antenna adapters but now I need the color codes to the wire so I can find the positive ignition supply and the negative supply?:dontknow: :dontknow:
kickinassrt-10 said:
How do I find if it is C2 and C22 wire?
Just looked at manual again, 11 is also a ground.
Back of radio the gray 22 pin connector.
Look for the wire colors below & disconnect the battery!
Second color is the tracer color(the stripe)
C2=FUSED IGNITION SWITCH PINK/YELLOW
C11=GROUND BLACK/LIGHT GREEN
C22= GROUND BLACK
1<--------------->11
I I I I I I I I I I I
12<------------->22
Why not just hook it up to the lighter connectors?
You mean the cigarette lighter? One is a ground and one is a positive right, but is it a ignition or constant power?
Kickinasssrt-10 I am unsure of where you are trying to hook up the wires. The wire colors for behind the radio are:
Also stated by Stagethree
Pink Yellow----Ignition
Black & Balck Light Green----Ground (There's to only need one)
Gray Red----Constant
You can't hook it up to the lighter plug because it stays on all the time! (Unless that is what you are looking for)
Is this what you are looking for???
I got it hooked up...I was looking for the ignition and ground to power the FM Modulator. It still has static even after being hard wired....go figure
You could also try grounding the unit separately!! Hooking aftermarket items to factory grounds are never a good thing. They seem to transmit alot of noise.
Stagethree said:
I should have asked you before.
What are you hooking up?
FM modulator for Ipod?:dontknow:
Yea I got it wired up but it makes some static, so I'm going for a new ground!
