Rear Clicking Sound?
THEWELSHM
Well-Known Member
Brandon Florida
When I pull off at a light there seems to be a clicking sound coming from the right rear:dontknow: :dontknow: Any ideas? There was also a dry kind of squeaking noise. Rear end or wheel bearing maybe:dontknow: :dontknow:
thewelshm
could be a pebble in the tread on one of your tires...lol
JTS VENOM PERFORMANCE said:
prob need to change the rear axle fluid, last time you changed it is?
Good point Ill check My service records:burnout: You think it may be the Limited Slip clutches?
thewelshm
thewelshm
its possible, see if it does it mainly n turns, or especially backing up
......as much as some people believe, fluid changes do not fix everything lol......the main bearing could be gone and tony would tell you sea foam would fix it lol fkn hillbillies!!!!
Mine clicks also, I havnt narrowed it down exactly but I think its the rear end...just started when I put the hts valve body in...... my hemi did a similar thing and was under warrenty still....took it to the dealer and it ended up being the rear end..... I have a set of cryo'd gears and full install kit standing by!
i would check the u-joints for play!! They get dry quick and squeek....
:rock: :rock: :rock:
What kind of lube did you use and did you remove the u joints to put grease under the caps
