Viper83101
Yea unfortunately not available anymore but man what a great tire.The KDW's are probably the best tire for these trucks. don't think they are available anymore!
VENM505
With that many miles I'd recommend rebuilding the limited slip too.49, 200 miles on it
VENM505
Be careful when going from 4.10 gears to 4.56 / 4.88 .. There's a carrier break between 4.10 and 4.56 meaning you'll either need a spacer [ not a good thing to do ] or you'll need to replace the carrier [best thing to do ].
I have an '04 and did the 4.10 to 4.56 swap and it's like night and day, 6th gear is actually usable now too.
--CC
I know there are plenty of other mods and honestly, around town my 6th gear is not usable at all. If im doing 60, which is pretty much any maximum service road speed limit, and I'm in 5th then im turning 1600-1700 rpm and I shift to 6th then im bogging down so I rarely ever get to use 6th unless im on the interstate which is rare. I def at least want to go to 4.56 gears not only to give me a little better acceleration but to also make my 6th gear a usuable gear for me for city driving (which is what I do most of). I have an 04 RC so I dont do any towing at all eitherWith that many miles I'd recommend rebuilding the limited slip too.
They also have thinner or thicker ring gears so you don't have a spacer or need a new carrier.
6th gear not usable? I use 6th gear even when towing, seems pretty usable.
I wouldn't personally change the gears(if I had an 05 i wouldn't change them to 4.10 either). There are just other things you can spend your money on that will actually make your truck faster, not just feel faster.
Man if I put my truck in 6th gear at 45 mph the thing would be likely to cut off due to not enough rpm on the engine to stay running. At 60mph in 5th im turning 1600-1700 rpm and if I shift to 6th at 60mph its drops to right at 1000 rpm. So basically around town my 6th gear doesn't even get used at all.Mines an 04 that I use to tow as well, a bunch of us do. I'm usually in 6th gear around 45mph, never had a problem with bogging. It's a cruising gear, if you want to accelerate then down shift to one of the other 5 available gears you have
I can drag that boat down the highway in 6th gear all day and not have a problem.
And I do understand that 6th gear is a cruising gear but im tired of riding around town in 5th gear turning right at 1700 rpm.
VENM505
Well I just went for a test drive so I could record a couple pics and here they are. I mean especially closer to 50 it just feels and sounds so bogged down its not even funny and that was on a flat road. If I had to start going up a hill I would have to down shift for sure so I really don't know how yall are even towing a trailer in 6th gear at 45-50 mph unless you just see something really off with what you see in the pics I just postedSomething doesn't sound right? Like ArrestMeRED04 said, I drove my truck around in 6th gear all the time (2004 RC w/ 4.10 gears). I'd shift into 6th at 40mph, and cruise to work without downshifting.
5th gear in our T56's is .75:1 - that's a tall overdrive gear. 6th gear is .50:1. That's a very tall ratio that was never intended for accelerating. 6th gear is intended to be used once you have reached the speed at which you used to be traveling.
Well from my pics, does it look like my truck is turning the right amount of rpm at each speed that I took a pic of?35 in 6th doesnt kill.: http://youtu.be/Ye-tmfY413E i did this video last time this topic came up. If its bogging bad at that speed, you shouls look into what is wrong with your truck by a qualified mechanic.
Dead on what mine does. Ive had the truck just under 8 yrs and have driven it at these speeds many times. No issue.Well from my pics, does it look like my truck is turning the right amount of rpm at each speed that I took a pic of?
VENM505
I mean there is no issue with mine as far as how it performs but I guess I would rather be turning 1300-1400 rpm in 6th at 60mph instead of just over 1000.Dead on what mine does. Ive had the truck just under 8 yrs and have driven it at these speeds many times. No issue.
