Rear hub bearing ?
Arska2
EU Moderator
Hamburg, Germany
Hi,
I am missing one bolt on my rear hub.
Is there any chance of buying a rear hub separately and replace it ?
Are there separate bolts available that i could use ?
Cant be a full axle swap just because of one bolt, right ?
Thanks
Arne
E, thanks. Thought there would be a full hub bearing available with bolts.
Just found a how to. Even easier :D
Take the break off
Knock the stud out from the front pounding on what's left in the threaded part
You have to make sure it's in a position where it won't catch on anything from behind
Put the new stud in from the back then thread on a nut with a stack of washers
Then run it home with an impact gun using it as a Press to install the stud
Make sure that the shank on the stud will not catch on the inside of the washer
Also don't use one of your good Lugnuts because sometimes it gets wrecked during the process
