Recalls for '05
JeffBoyette
Waldorf, MD
Does anyone know of any recalls for '05 srt-10's. I heard of the door seals, the wheel bearings and the subwoofer but didnt get much info on either. If i am the second owner will they still honor them? Any help is greatly appreciated.
transmission & yes as long as they have not already been done.
Also check the crank bolt to make sure it is tight. That is for low mile 05's
Bruce
i checked with my stealership & Dodge customer line & either one knew of a subwoofer "recall". is there really such a deal & if so anyone have a TSB number?????
does anyone have the numbers for all the 05 recalls ,,that way when i take my sled in i can hand them the list so they cant bull snit me
There's a TSB for the Governor Pressure Solenoid on the 48re transmissions. Our QCs were overlooked in the listing but it covers them. Just had mine done last week.
oldguy
Also check the rear main seal for leaks and some 48re trans had problems with internal parts missing. Mine for instance was absent the spring in the accumulator which led to smoked clutches and burnt steels. Symptoms were extremely hard 1 2 shift and after repeated runs under WOT delayed 2 3 shift. Reason, smoking hot trans due to lack of fluid to clutches b/c of missing accumulator spring.
When I check the vin for recalls on the dodge site it says there are no incomplete recalls or customer satisfaction notifications exsist...So why don't any of the recalls show up ???? anyone know ?
I bought my truck new so if there were any recalls, by law they would have had to notify me. No notices. Also if you have your truck serviced at a dealer, they will run your vin and if a recall has not been performed they will notify you. Do not confuse a recall with a TSB.
