Ah Ha! I knew it came from a reputable source...Dave at Roe Racing...
http://vtcoa.com/forums/showthread.php?t=13583
-Joe
-Joe
he has an '05, your '04 pads won't fit...........FSTJACK said:I have the Performance Friction on the red truck and they are quiet, stop well, and are virtually dustless.
I have a set of EBC's that I put on and replaced after 1500 miles. Pay for shipping and they are yours.
I also have a new set of EBC pads that I will sell cheap, Front pads for an 04 for 50.00 delivered.
moparracing said:i have nothing but praise for the centric posi quiets i bought from dave z...... :rock: :rock: :rock: :rock: frankly, this is the first complaint i've heard about them ?? the last guy who still had noise didn't PROPERLY bed his brake pads......
http://www.zeckhausen.com/bedding_in_brakes.htm
i would give this a try before you spend alot more money on those dusty ebc's... performance friction could only be an option if you had an '04 - which you do not.......
RUFROZN said:how did you guys bed them? on the posi quiets ive tried the 60mph to a near stop and repeated about 4-5 times and i have done this 3 times now and they still squeel like "DELIVERANCE"- thats the reason iam making the switch- what are some good secrets?????????
you seem to be the only one with problems with the bedding steps...... you may want to consider taking it to a professional......:dontknow:RUFROZN said:how did you guys bed them? on the posi quiets ive tried the 60mph to a near stop and repeated about 4-5 times and i have done this 3 times now and they still squeel like "DELIVERANCE"- thats the reason iam making the switch- what are some good secrets?????????
You also have to lightly sand the rotors (non-directionally) and then wash off the rotors before you install new pads. The old pads leave a "film" of contaminants on the rotor surface and it will cause the new pads to squeek if you don't clean them off. Did you do that??:dontknow:RUFROZN said:how did you guys bed them? on the posi quiets ive tried the 60mph to a near stop and repeated about 4-5 times and i have done this 3 times now and they still squeel like "DELIVERANCE"- thats the reason iam making the switch- what are some good secrets?????????
done lotsa brakes in my years, but expert -- no........RUFROZN said:yes it did clean the rotors- and i reinspected them again last night- i think i have a rotor issue- not a pad issue as such so i believe that once my new rotors get here i think my problem will go away- iam still going to go with the green's, poor timimg most likely when i put the posi quiet pads on- because even the stockers squeeled thats why they got replaced in the first place.
Hey MOPARRACING- i will figure it out- if you are a brake expert i will run my truck down to you- are you?
