removing dealer badge
seth
Northern Virginia
I searched around but couldn't find an answer. My dealer put one of those annoying sticky badges on the tail gate. What is the best way to remove? Looking for cheap and easy.
thanks
Hair dryer abd fish line
depends on the badge. usually they are just flat vinyl and that scrapes off pretty easily with a fingernail or a credit card.
seth said:
Its the typical plastic one with a sticky back
Applying a low to medium heat to soften the adhesive works very well. You will most likely need to clean the residue. Usually just a damp soft cloth should work for that.
What the guys said...you can use blowdryer or adhesive remover.
If you need step-by-step, its in the DIY Section
Thanks
-Red
Thanks
-Red
I was going to mention that but seth needs a star first :D :rock:
Use a hairdryer and plastic scraper, and if you have residue left behind from the sticker, try "cheap" car wax if you have any ( these usually contain kerosene to get the carnuba to be soft enough to use and gives the smooth-slick shine) a little kerosene will remove the glue and soft soap and water will cut the kerosene...my $.02....good luck
warm it up like everyones' said ...either by letting it sit in the sun (depends on where you are though) or warming it with a hair dryer, then use some 30lb. fishing line and saw back and forth behind the badge (if you wrap the line around your fingers..wear gloves). then use some goo-off to remove the left-over adhesive...polish and wax.
slow91 said:
You need a star to see the DIY Section
It's worth every penny :rock:
It's free on other forums.
Seth check out next post, same question I asked yesterday answers to follow
