Then the front is gonna be higher than the back with rc springs. It doesn't drop it that much. There is nothing wrong with spacers. But it's your truck do what u want
i bought some rc srt front springs, they work great and raised it about an inch, btw my way to change springs is to remove the 2 lower control arm bolts and nuts along with the shocks and sway bar, dont touch the ball joints, and have a jack under the control arm, slowly let the jack down along with jackstands under the frame and the spring comes out easily, reinstall and use taper punch or screw driver to align the lower control arm mounts and install the bolts and well you know the rest.
For the lower control arm bolts, what are the torque specs for the nuts? I've seen 150, 160 and 200ft lbs. Going to go the route mentioned above by 572mopar and trying to forsee any issues that may come up in the process. Thanks in advance.
Ran into some problems/issues while trying to change out the front shocks and springs. Found out I don't have big enough sockets to remove the lower control arm bolts that attach it to the frame.
Where the spring sits on the lower control arm, it appears that something is coming through the lower shock mount hole (see pic). Is this a pad or something else?
My other question is on the 3rd pic. It seems that the bushing is awfully contorted where the tie rod meets the spindle. Is that ok or is there a way to make that better?
Thanks in advance
Thanks for the torque #'s. The truck is in the air in these photos
