Removing rear rotors on a '05 QC...
KRAZYSRT10
Is there anything special to this? I should just be able to remove the caliper, brake off those little retaining clips and it slides right off....right?
Or do I have to take the axle apart?:dontknow:
T.I.A!!!!:)
T.I.A!!!!:)
there may be some little washers holding the rotors on that youd have to remove.
The e brake, it's a drum on the inside of the rotor. You need to remove the dust covers on the back of the drum. Then use a flat head and push on the clicker until the rotor is free...
