I am getting ready to install a backup camera to my aftermarket head unit and i need to know the color and location inside of the truck of the reverse wire so that i can tap into it. Can anyone help me with this info
pull the taillight and find the reverse light wire color. remove the driverside kick panel and find that wire. test it to be sure. I think it should be WT/LG.
I just did this upgrade, I tapped into the rear right brake light and soldered it in, you are taking the wire from the camer back there anyway. So piggy back them together over the fuel tank up to the motor and pop the grommet to get in the cab...
