RAMviperIFFIC
Last Fall, I hired a "paint wizard" portable businessman to fix my paint chips in my truck. He did it at work in the parking lot ($100 flat rate), so I got to go out and watch and learn.
Well, after a Wisconsin winter driving season, I have about 12 small chips again. So, I went and got some touch up paint and got some clean polishing rags. You also need a solvent, I chose to use 3m adhesive remover, as it is safe for cured paint and clear coat.
As you may know, when you dab on paint with the wee brush, the paint applied is higher than the factory paint. Put a dollop in all of your paint chips after using you solvent to clean the area. Let it cure for about 1/2 hour to 1 hour.
Now comes the magical part, get your rag pretty saturated, but not dripping with solvent and lightly rub in circles around the dollop'd area. In a few seconds (less than 30), the high paint lifts right off and you are left with the chip filled in. I can't believe how easy it was and I got the same results as last fall. Please note that as I learned last fall from the professional, it passes about a 5 foot inspection test, any closer and after staring, you can find the repaired area.
I am going to try multiple applications each weekend for a while and see how much each week, it improves (hopefully.)
I only have about $15 dollars invested and about 1 hour of my time!!!!! And the supplies will probably last a year!
I know, pics, pix, pictures!
