faslane505
counldnt find anything on the specs for our rods.... i.e.
rod length, big end I.D. and the Small end I.D.
your too damn technical:argh:DevilDawg3097 said:CONNECTING RODS
DESCRIPTION
SPECIFICATION
Metric Standard
Bearing
Clearance
0.005-0.074
mm.
0.0002-0.0029
in.
Desired 0.0381 mm 0.0015 in.
Wear Limit 0.0889 mm 0.0035 in.
Piston Pin Boar
Diameter
23.940-23.978
mm
0.9425-0.9440
in.
Side Clearance
(Two Rods)
0.25-0.46 mm 0.010-0.018 in.
Wear Limit 0.51 mm 0.020 in.
Total Weight
(Less Bearing)
598.4 grams 21.11 oz.
CRANKSHAFT
DESCRIPTION
SPECIFICATION
Metric Standard
Connecting Rod
Journal
Diameter
53.990-54.008
mm
2.1256-2.1263
in.
Out-of-Round
(Max.)
0.013 mm 0.0005 in.
Taper (Max.) 0.013 mm 0.0005 in
End Play 0.051-0.178
mm
0.002-0.007 in.
Desired 0.13 mm 0.005 in.
Wear Limit 0.254 mm 0.010 in.
Main Bearing
Clearance 1-6
0.025-0.051
mm
0.001-0.002 in.
Wear Limit 0.076 mm 0.003 in.
