Roe 10LB Pulley....
TNVIPER
God's Chosen Land....East TN
Used but as good as new 10LB pulley for the Roe SC....gave me 9.3LB but my heads are PP which will drop boost PSI...should give 13-15LBs with Stinker's 7" crank pulley.......requires either idler pulley or belt change...and a retune.....$125 shipped anywhere in the USA...
is the VEC3 for sale?
aaahaahahahahahahaahahahaahahahahahahahaha
blackviper said:
What pulley combination are you using Larry?
Stinker's 7" crank pulley with Roe's std 5.6LB pulley....getting exactly 11LBs with that combo.....I expect the 10LB would yield 13-14LBs....thought about installing it but figured it would be a strain on everything even though I am forged...
Already have one Larry...should I get yours to have a back-up?:)
