Roe blower belt slipping
94rt10ohio
Curtice, OH
My belt began slipping late last year. Since it was late in the driving season it is still slipping, but it is time to get back out of the garage and I am not going to drive it this way.
Anyone know how big it is? I am going to E-mail Roe, I am sure they will answer. I want to grab one at a local place, but slightly smaller since my pulley is also now slightly smaller....
need a bigger idler pulley sean will hook you up I just got my 10lb today with a bigger idler and you will still be able to use the same belt:rock: .
I believe it's 2345mm. Hopefully, someone else will chime in to confirm.
This should solve your slip problem...I used this when I changed to the 10LB pulley..
Idler pulley from NAPA...Gates 38042 Backside Idler Pulley...
There ya go thats the one I got today 22 bucks:burnout:
Same belt from Roe with this pulley?
Thanks, will give that a go.... Now the challenge, to find a local parts joint with it in stock. It sat all winter and now I have a bug up my butt to fix it now... Go figure.
the belt size depends on the pulley size, and the motor.
sean's phone number must be floating around give him a shout
Could not find the Gates local, but did find a Good Year that worked. No more slip, at least testing in the garage. Will be a few days before it hits the road, weather taking a turn for the worse.
Almost done with spring cleaning, just the interior remians.... Maybe someday I will get some new rotors!
Just paint em and resurface them, look good as new:rock:
