perk_1405
what should the gap be on the plugs supplied with the roe kit?
TIA! elliott
TIA! elliott
33-34perk_1405 said:that was fast. thanks dog
I meant 30-35 but for some unknown reason that is what I gapped mine at was 32 but not I am going back to bosch platinum IR Fusion which are preset at 30 the colder the gap with out highoctane you will get a rough Idle, so the ngk IR's like said gapped 32-35 32 on the on the cylinders 1-5 and 35 on the rest have had a detonation problem yet with no meth.505'sFastestViper. said:33-34![]()
mr. anderson said:you guys use platinum plugs in a blower app! you fellas have some major cajones!!!
that is for paxton. Was running platinum then ngk iridium now back to platinum ir. Colder plug means less detonation but can also Idel rough. plus that is more for emissions standards then for performance. The epa now is going after the people who make the cat sims. Which is bs because they state for off road use onlymr. anderson said:hmmm. page 1-1 of the install:
http://www.paxtonauto.com/pdf/manuals/4809645.pdf
"Before beginning installation, replace all
spark plugs with NGKZFR6F-11 (follow
the procedures indicated within the factory
repair manual and/or as indicated on the factory
underhood emissions tag). Do not use
platinum spark plugs. Change spark plugs
at least every 15,000 miles and spark plug
wires at least every 50,000 miles."
not sure as 2 indexes would reduce the issues from the platinum in a boosted app (predetonation and detonation).
can you tell me who recommended a platinum plug for your app? IR plugs are fine and are used in many boosted apps but never have I heard platinum being recommended in any heat range.
You can get them for about 50 bucks you can still check these plugs for detonation and such just dont have to worry about blowing out the gap on them that is the plus constant gap mean constant spark. Just a thought I will let you guys know how good they work and how long they last.mr. anderson said:hmm, haven't really paid attention to the latest and greatest of spark plugs, those do look interesting, I would be interested in the amount of platinum to IR ratio that make up the core of those plugs. since it is a mix maybe it might be just fine. how much they stealing per plug?
I'll just stick with my copper plugs. I like to check my plugs every 5k miles anywho. old habit, even though you can only read so much into it.
I saw those awhile ago but know one had em was gonna try them, also the competior plug they used was the bosch fusionYellow venom said:Anyone try these E3 spark plugs?
http://e3trucksparkplugs.com/
DevilDawg3097 said:same cost as the bosch at jegs. pt E 3.58 for our trucks just may try them outhttp://www.jegs.com/i/E3+Spark+Plugs/368/E3.58/10002/-1
yes I watched it. thats why I went with the bosch (not becuase of the video)but researching into thm when they came out, now I know I can get the e3's. People dont realize how important plugs are just like good motor oil. The price is not that bad considering there life. Thanks for the renminder:burnout: :burnout:Yellow venom said:Did you watch the video clip of when they dynoed them? A little HP gain too:rock: and better fuel economy![]()
