Roe TB Users
Tooloe
Central Texas
i have a question for you guys i have a Roe TB.. but with everything installed the throttle body blade still wiggles..and over time has scared up0 the polished part...does anyone else have this same problem? i sucked a screw off the TB shaft the first time i blew my motor and do not want to do it again:D
I used loctite has never moved.
Before doing anything drastic like welding, why not try what ELITE did above with the Loctite? It sounds like a good and simpler way to go.
The best thing to do is get one of those automatic center punches and use it to mar up the threads for the screws. If the threads are damaged a little bit they wont come out on there own.
