Roll control line lock
JTS VENOM PERFORMANCE
Preferred Vendor
SRT10 heaven
fixin to install my line lock, but got a q?
I figured on after the abs block, but wanted someones opinion that has allready done this.
before or after the abs unit? thanks:p
Before the ABS :D
How much do they run?
Any vendors carrying them?
What's a good system?
I got the Hurst Bone, seems it was in the $100 area, i know jegs, and summit carries them, not sure about any of our vendors:dontknow:
But tci, b@m make some also that are a tad cheaper $ wise, and I think Jegs has there own brand for around $49 or something close to that.
............................dumbass Django........................
.......I always wondered how you fkrs do that front brake burnout shit......
..............someone gimme a guitar please................
SD
How well is it working?
I heard some Dodge tech guy said that the fittings were strong enough for the pressure? Any truth to that?
I have had zero problems.....
The stock switch that comes with the Hurst unit is a little cheap...so I used a different switch....other than that....all good...
Thanks. I have been looking at that one for awhile. Did you get the install kit with it also?
just the unit....Fabricator made the bracket and DC Perf. shaped the lines....
