Rotor upgrade?
InfinitySRT
MD
Been reading some of the posts and didn't find a "real" answer to this question so I felt a post was in order. My OE rotors are wearing thin, time for replacements, what upgraded rotors is everyone using? I don't think I want a bir brake kit, prob just looking for a slotted rotor and better pad (was reading the recent pad post) might do a cross drilled/slotted but had bad deal with a cross drilled rotor in the past :dontknow:
I'll be replacing all 4 rotors next month with Centric slotted rotors from Zeckhausen:
http://www.zeckhausen.com/Dodge/Ram_SRT10.htm
(pads that don't require filing are also available)
Apparently EBC has some dimpled & slotted rotors. A VTCOA member recently had is several-month-long order arrive and installed his:
http://www.vtcoa.com/forums/showthread.php?t=10776
Not sure on availability.
The other option I've seen are some crazy drilled designs on FleaBay (that may or may not fit).
And then there's always OEM. :)
Kevan, keep us "posted". Thanks :)
i replaced my stock rotors with slotted and drilled rotors from disc italia. i ordered them from brakeworld.com. bought my pads there too. stopped the squeaking and all the brake dust also.
i`m thinking of a re-mortgage so i can afford them.:D
Daymn!
For $1200 I hope they get you chicks too. :D
Tyler, check out the link Kevan provided... There is some info on drilled and slotted rotors for our trucks.
Was afraid the rotors were gonna be BIG dollars, that's why I wanted to stay away from a big break kit, that would prob run 3k or more:dontknow:
I'm gonna check out Kev's link, I was also told Stopteck had some stuff. Worst case I just replace with stocks, just wanted a something that performed a little better and looked nicer.
