A/F at idle will jump around between 14.6-15.2. At cruising it will be right around the same, but tends to jump around a little bit more. The PCM is always adjusting to stay at 14.6 during closed loop. You can not do anything to make it run any richer during closed loop unless you reprogram the PCM (I don't recomend this). Now on at WOT (open loop) all bets are off that's what you can control. For a N/A engine 12.8 to 13.0 is good and for FI it is safe to run 11.5 to11.8 as a rule of thumb. I figure it would be the same for the Nitrous as well. Remember leaner is "meaner" makes you more power, but richer is "safer" not as much power. The is a fine line as we all know with the recent engine failures. Remember you gotta pay to play in one way or another.
When ever you're putting power adders i.e. (flashed PCM's, FI, Nitrous) I would recomend that you install a wide band A/F meter. It could save you from going BOOM!
