Hi Dan and crew. Is there an option on your PCM flash (I have your blower flash and inlet system) to go into a "safe mode" if/when the truck goes over a certain temperature...either water and/or oil temp? I wasnt sure if this was built into the stock pcm or on yours.
Also, when the fan kicks on sooner with your flash and the 170 thermostat, does it kick in to high fan speed or low (regular fan speed), or is there only one fan speed for the truck?
After doing 2 days of road racing in 95 degree temps I was just curious about whether the computer will go into a safe mode (to prevent engine overheating) and if the fan goes on does it have a high and low fan speed setting that could be adjusted to just run on the high fan speed setting.
