I bought my SCT from Roe back in November and have used it several times to flash back and forth between tunes. When I got home from the 'Nooga GTG
and tried to flash it from stock, I got "ECM Unlock Failure" - tried again, same thing. I disconnected the battery for about an hour, hooked it up and tried again-"ECM Unlock Failure".
I got tied up with selling our house and moving for a while, when we got settled in I finally emailed Sean Roe about it.He's been great trying to help me through this. He told me to check my battery voltage and the fuses-all good. We ran through all of the info in the unit (VIN, serial #, ecm #), all good. Sean was stumped and referred me to SCT tech support. I spoke with Rudy there. Rudy bent over backwards trying to help. We again went through all the info in the SCT, he sent me a recovery file-no luck. He sent me a couple more files and helped with a software issue in my laptop-no luck. Rudy was stumped and had me send the unit in for a replacement. I recieved the new unit 3 days later and Sean sent me the new performance tunes to load up. I jumped in the truck, plugged in my SCT, ran through the menus, selected the 93 oct tune(so far so good), followed the prompts and.....
ECM Unlock Failure:argh: :argh: :argh: :argh: :argh: :argh: :argh:
Can anyone here help:dontknow: :dontknow: :dontknow: ? What could possibly be causing this? The SCT unit is ok, I can read DTC's and see battery voltage. I can read the VIN and ECM # through the diagnostic menu, but when I look at the data stored in the new unit-no VIN or ECM#.
Help, this is frustrating. I have some parts I can't use until this is squared away , and I'd like to get it fixed before the SE GTG.
:argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh: :argh:
