I'm doing a little research for my next mod, and I'm kinda stuck on choosing either the SCT programer or the VEC3. So I need some help from you guys that are running these in your truck Pros and Cons.
I know the SCT programer is just plug play, but you can't really make any adjustments. (Don't have to hack up the wire harness) I know its been used successfully in Paxton trucks.
I know the VEC3 has alot of customability options such as fuel curves, timing curves, you could add meth (which I plan on doing) ect., but I have really not seen any of the Paxton trucks using it. Is because of the split second controller?
Any help you guys could give me will be much appreciated.
