SEAT BELT ALARM 06
REPOMAN1
EDGEWATER , NJ
Does anybody have a 06 i bought mine it came with no owners manuel and if so can you let me kno0w how to take the seat belt alarm off .. i thinks its under belt minder .. kinda stupid question but its annoying everytime i get in it .. my 09 4500 dodge i took it off but the code for the 09 didnt work on the 06 .. thanks Rocky
i'll take a look in a bit if no one chimes in.
Just curious, what does it do? I dont remember mine making any noise, but then again it MIGHT get driven once a week.
Page 35
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. With all doors closed and the ignition switch in any
position except On or Start, buckle the driver’s seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON position, unbuckle and then re-buckle the driver’s
seat belt at least three times within 10 seconds, ending
with the seat belt buckled.
NOTE: Watch for the Seat Belt Warning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
NOTE: Although the Enhanced Warning System
(BeltAlert) has been deactivated, the Seat Belt Warning
Light will continue to illuminate while the driver’s seat
belt (all models) or the driver’s or passenger’s seat belts
(1500 standard and quad cab models) remain unbuckled.
It beeps for the first like 5 mins you drive its very annoying .... Thanks for helping me out
You should wear your seatbelt :D
I know i keep hearing that and the messed up thing is i was just rearended in the 09 4500 by i guy texting he was doing at least 50 1/4 inch steel bent the back of the truck its on top of the back wheels ...
i just took the seat belt from the middle seat and buckled it to the drivers nd when i wanna wear mine i buckled it to the middle seat belt...it is backwards tho but works
06 models dont have a middle seat.....
