zeleny
I would appreciate any tips on alternative ways of wiring a second battery.
Something like a run-on tailgate party. I'm using a 2800 watt Yamaha inverter generator as my main power source, and the second battery as backup for various bed-mounted accessories.Depends on how you want to use it. Why are you installing a second battery?
I just threw a second battery on the passenger side, Negative went to a ground point and the Positive I ran back over to the Positive of the orginal battery.. Doubles the Amps but keeps the Volts the same. Alternator has no problems charging both and running all the other electronics Ive added
If it were me, I would use a battery isolator. Do a web search and you should find wiring examples.
Basically it will allow both to charge, but will isolate them so you don't kill the starting battery.
I'm MECP certified in 12v and did car audio for 12 years, but what do I know
