azpyroguy
At first glance I thought I had a problem because I was seeing oil on the driver side of the engine.. but no loss of oil pressure, no oil in coolant, etc...
So I looked bit closer.. and noticed a small stream of oil coming from beneath the oil filler cap....
It runs down the side of the valve cover, under the header flange, and onto the side of the block... and on down making a mess the whole way...
Anyone had this issue before... or if there is a TSB for the cap leaking...
