NukeGM/Ford
you said you have a venom shifter, do you mean Tony at JTSVP or is the brand really Venom??
probably the solenoid for the lockout. mine does it almost all the time when its hot, only sometimes when its cold. turn the truck off and it goes right in immediately. need to get my fat arse under the lowered truck to remove it. i wouldn't worry about going into reverse at speed if you get that far over it will grind some first anyway. proper hand position will prevent you from going that far
