Silverstar replacement bulbs
i got the ultras in my fogs and i'v got the regs in my headlights...an i love them... i'll check and see if i got some pictures if not i'll take some tonight.....you can tell a big diffrence.....i just wish there was a way to run your bright lights and fogs ayt the same time
from a truck driver...........I dont like u:p LOLOLOLOLOL
yeah it would be nice to do that, only prob I have is late at night cuttin cross the US, I run into those people with HID's and fogs, and they are soooo sleepy they forget to dim:( MAN! they dont realize thats a blinder:D LOLOLOL
hahahahaha...yeah i heard that... if one of my hedlights ever goes out i'll put the ultras in the heads to...i think the ultras are a little bit brighter and cover a little bit more.... but the regs are very nice upgrade over stock.. ill get pics tonight.... yeah i drive home form my gfs house "45 mile drive one way" at 3 or 4 in the morning at pretty much mock2 or close lol so the trucks only see me for a second lol
Thats one thing I noticed on the stock headlamps, I dont drive mine much at night , but dang! the stockers suck! ya cant see hardly 10 ft infront of ya:D
specially at mach 12:burnout:
What's the secret to swapping the headlight bulbs? I went out to do mine the other night but it was dark and I didn't see a real easy way to swap those out.
--wes
i have them in both heads and fogs huge difference wide spread arcoss road ill post up pics when it get dark and you can tell
--wes
yant me to take some quick pics for ya bo? I kin if ya want:D
--wes
bro thats takes 2mins two 10mm on the side under the hood one on top of the other and the one between the headlight and corner of bumper
it's real easy man... can't really see them nuts at night...look at it again... it's real easy
there is a thread on here about havin them both on. fog lights on when high beams on is the title. don't know how to post a thread yet.:rock:
ZCx
Hmmmm...i wonder if the Ford headlight switch mod will work on Dodge?.. There is a way to make them work on Fords. I'll find the How to and post it up and see if you can at least use the principle/idea and see if yours can be done the same way.
***EDIT*** Ok here it is. This might help...hell, who knows, they might even be made by the same company...stranger shit has happened. I hope this helps in some way. http://www.svtlightnings.com/svt/how-to/foglamps/foglamps.htm
wheres the pics of the ultra's at night guys? post em up If you could, I'm driving across Canada this spring and am going to get a good set of headlight bulbs. From what I can see everyone seems to like the ultra's, lets see the pics. Thanks
Yeah I agree with ya there Stinker!In the same boat!:burnout:
sorry guys i completely forgot about the pictures.. i'll try to snap some in the garage b4 i go to work
ok only night pictures i have right now you can kinda get the idea
sorry they are not anybetter but you can still tell they are a hell of alot brighter than stock
Thanks for the comparo pics Tooloe, definatly shows a big difference, Silverstar Ultras it is!
--wes
There are three bolts, 10mm, that hold the headlight assembly in on pass and driverside. Pop the hood and looking at the front you will see a honeycombed bracket. Driverside has the outside temp sensor on it in the front. Use a long extension to get to the bolt on the bottom of the headlight assembly between the bumper and headlights. See attached PDF for pics and instructions. These are easy to swap out. Be careful not to scratch your bumper with the extension. The fogs you can crawl underneath and reach inside the hole to twist out the fogs. Don't touch the bulbs will make them burn out.
View attachment Headlights2.pdf
