Slave cylinder (need help)
i purchase a oem parts or remplacement parts.....
not an upgrade at this time....
that one will NOT work its for a viper car, our slave cylinders are different. PM TheMoparConnection he can get you the correct part number
what's the difference between the Ram and the viper gearbox(or clutch)????
thank you
Pm sent
but what's the difference between a viper and a ram srt10????
if you have some pictures,i'm interested:D
the size...
the viper slave isn't as tall as the truck slave, and it uses plastic parts where the viper's is metal...
the connections aren't the same to your master cylinder line, either...
you have to shim it to make it work...
not worth the aggravation in my opinion...
i have some pics, but the only thing you can see is the difference in height... and it's only 1/4 inch or so...
yes...
though i've gotten over 60,000 miles on an oem slave, and i drive HARD;)
so all the little things you have to do to make the car slave work don't outweight the ease of installation of the original truck slave...
but what do i know... i only have 110k miles on mine;)
