Slicks
CubanEvo
Pembroke Pines, FL
Hey guys just wanted to know what i need to do to put SLICKS on the truck.:rock:
You need to either buy a modified rearend to put any size slicks or shave the rear calipers and you could put 16 inch rims with M&H Nostalgia slicks.
If you shave your own rear calipers it will take six to eight hours per caliper...a real pain in the ass.
Get Stinker to order a new rear end for you from DTS...you will save about 100 lbs, be able to run any sized slick you want, have any differential ratio you want, avoid the spider gear/broken axle issues and have a Detroit Locker all at the same time.
He it is installed:
Shaving calipers is like performing some sadistic penance :D Dont wish it on anyone.......Now that its done, love the slicks :rock:
If you're not on a budget, then the DTS is the way to go ;)
