muscletrucks
I hope he has to re-take his "landing on a ship" test...
http://view.break.com/156476
Seriously, what do you think happened?
FlyingLow said:Well the best I can tell is he was in the water on purpose probably droping off some type of special forces team for a demo or he was already single engine. Now when he takes off he gets up no problem but looks like he loses a engine or he does not have enough power to hover single engine. He takes the landing flat as is procedure. Now he has to perform a single engine water take off. Which is basicly a water taxi until you get about 5-15 knots ground speed and then taking off. Somewhere between 3-15 knots airspeed you hit translational lift. Translational lift requires less power. Which is ideal if you are already maxing out your power required. Then he puts in to much nose foward (to build up ground speed) and causes the rotors to impact the water. You can't put more then just a few degrees of nose down (forward) when you water taxi. BTW this helo is designed to land in the water. It's bottom is just like the hull of a ship. Much like the mighty SeaKing.
Silent D said:That was some fugly shit......Hope they all got out alive.....
Reminds me of this video:
http://video.google.com/videoplay?docid=1365353836237246497
SD
FlyingLow said:
Black1 said:Jesus MAN!!!That was pretty spectacular! WTF happened? Wind Shear? :dontknow:
