Overkillsrt
- Joined
- Nov 9, 2012
- Messages
- 148
- Reaction score
- 0
I was wondering if anyone has tried E3 plugs or any other performance type plug
I just know how we all want to squeeze every bit of power we can out of these things and I know on most engines the gain a few hp and better mileage
I had E3's they worked good,there has been one guy that had the end come off of the plug and went through the engine and caused alot of damage!,And the other issue is that when you run your truck hard the end of the plug can get so hot that it will actually preignite your fuel before the piston gets to the top of the compresion stroke!
Im running basic NRK's now with no problems.
So basicallly stick with what works Champion or NGK,and DON'T go platinum.
I know there hasn't been too many problems with champions in our trucks, but after having so many problems with champions in small engines dirt bikes quads and others I won't use them....I never really noticed this until I started working on small engines at work about 8 years back....I couldn't believe the failures vs the ngks that were in everything else!!....I wouldn't even put one in my weed whacker!!
