Speaker Install Tutorial and Review
JeffBoyette
Waldorf, MD
Replaced all the speakers in my truck today with the Boston Acoustic SC series. I'm going to go over afew things I ran Into with the Install, and give my review on them.
6x9 Door Speakers
1.) The bit to remove the door handle is a T30 torx. Don't drop it into the door. Two Philips on the bottom of the door, one behind the handle, one on the sail panel. Just pull up on the hand grip and it pops off. Remove 2 wiring harness clips for windows door locks and mirrors. When installing door, put the bottom in the slots first, attach the harnesses, then guide the door lock stud in the hole. Push down on the handle and armrest to seat the door and screw it down.
2.) The 6x9's by B.A. have much smaller magnets and are more lightweight than the infinity oem.
3.) The bracket that looks like its made into around the oem speaker needs to be removed and installed on the new speakers. (Didn't realize this until second door.)
4.). The cructchfield connector used to clip into the factory wiring harness, fits the factory harness but is too small to fit the spades connectors on the B.A. speakers. Had to splice the supplied B.A. harness with the crutchfield harness.
5.) 2way or 3way 6x9's are a waste of money if running the factory headunit without dedicated aftermarket amp. The factory infinity amp, has a built in crossover to limit frequencies to door speakers to only mids. The B.A. 6x9's have built in crossovers for the tweeter and supertweeter, so it won't even get an audible signal with the factory power. I'm sure they will sound even more phenomenal when I install a 4 channel amp.
6.) Sound deadening is pretty decent on the doors, and Dynomat would be a difficult install because of all the channels to attach the door.
3-1/2 dash speakers.
1.) The front little panel against the windshield pops straight up after you get a screwdriver under it, then pulls out toward you. Sounds like its breaking. No worries.
2.) They do not make a harness to clip into the factory for the dash speakers. You have to cut it off and splice. Cut close to connectors because there is very little room to work against the windshield. Careful when stripping the wires, that you don't tap the glass on accident.
5-1/4 rear speakers
1.) You have to pull the rear tray and subwoofer out. 1 Philips on each side of sub. Pull it out and the third hidden screw to remove the tray tray is under it. After tray is popped out its easier to remove panel over 5-1/4.
2.) Slide the seat belt guide all the way to top, it makes popping the 5-1/4 panel easier.
3.) THE FACTORY SPEAKER IS A 3 BOLT. AFTERMARKETS HAVE 4. NOTHING LINES UP. You have to buy a separate adapter bracket or mark, drill, and tap. That's what I did.
4.). This was the only harness that was plug and play.
Review
Because the factory sub is so weak, i run Bass 8 Mid 2 High 6
The factory speakers, do not get much louder after Volume 20-24, After 28 it just distorts.
With the Boston Acoustic's, the highs were so crisp and clear that i turned the Mid to 0 and the High to 2. Volume is linear, all the way to MAX. With no distortion. The bass still falls on its face after 20-22 but i attribute that to the subs. After 28 I can hear the sub clipping and popping. I unplugged it to listen to the Boston Acoustics without it... and again i was able to max the volume and things were still very clear.
Much more performance to be had with a dedicated amp for these speakers. The 6x9's will perform to their potential, because the Infinity amp filters highs from the 6x9's so the tweeters do not even work. I verified the Boston acoustic 6x9 tweeters work by plugging them into the dash speakers as a test. They sounded SO MUCH louder and clearer on that channel.
I have a master install sheet for the 06-08 dodge ram. Most of it is the same for the 04-05
It includes pictures, descriptions and tutorials for replacing everything from the head unit to the speakers. Every step of the process, every screw for every panel. It is the guide that the tech support use at Crutchfield to provide customer service so they seem like they know what they are talking about.
Email me [email protected] if you want me to send you the PDF.
Oh yeah i might also add.. dont waste your money on upgrading the rear 5-1/4 unless you are installing a 4 channel amp. I played with the fade and balance testing all the speakers, and the fronts overpower the rears with just a few clicks up from full rear on setting. They completely disappear from the sound stage after three quarter faded to the rear and probably have 1/4 the output of the fronts.
sweet:rock::rock::rock:thanks:rock:
good write up. in my QC i added a head unit, a 1000w 4 channel pushing the door speakers and 4 tweeters. i left the dash speakers alone. then i ran a 1000w mono pushing two 10's in a pro box under the back seat. you couldnt stay in the truck and half volume.
Good write up bro, love the way Bostons sound. I also opted for a more agressive sound on the inside to compensate for the outside. I took out all the factory equipment and replaced it with a Pioneer single din, Focal components, and two 10" L3s behind the seats. One 1000w amp is running the subs and I have 400x2ch running the Focals. I had the rear speakers replaced but I'm not running them to an amp, can't hear them anyway. I'm happy with the set-up, perfect for my needs. Post some pics of your set up.
Don't have the file anymore and don't remember much about the install, but I'd you put a testlight or multimeter to the wire and touch it to a seat mount bolt... you can see If It's ground or positive.
