I am gonna do this kinda quick tonight, post up a little summary and then some pics
but after the clutch is removed
install the new flywheel , add some blue loctite to the flywheel bolts, trq to 55 ft lbs
install the new disc, install the alignment tool, then install the new pressure plate
more blue loctite then trq to 200 inch lbs
next install the slave cylinder on the transmission, then remove the alignment tool and install tranny.
fill with fluid of your choice mine is redline d4, driveshaft install,
and if you are doing the upgrade install the new mastercylinder, connect bleed and your good to go.
now this is Mr. Stevens tranny, it was upgraded with cryoed gears, and rem polished gears, next we did the new master / slave upgrade, this is a new slave with billet parts so they can withstand the heat and pressure, also comes with a new bearing
you also get longer carbon braided lines , one to the master, one for bleeding, that has a fast bleeder on the end.
(now this fast bleeder, you basically very lightly loosen it up, then you depress the pedal, let up , it has a check valve inside and will not let air in) I bleed the system in 5 minutes by myself.
next you have a new 7/8 bore wilwood master cylinder, with our own tooled rod and aluminum adjuster, this way you can adjsut where the pedal will be, it is also machined for the ign switch that allows you to depress the clutch and crank the vehicle.
also there is a billet aluminum adapter to adapt the master to the firewall
you will notice too in the pics the new lines are alot longer allowying one to route them very clear of the exhaust to help reduce heat problems
all parts are 6061 billet aluminum except for the slave parts which are a heavier grade aluminum,
I will get more pics of the rod and slave tomorrow
